furb
- 9:13 PM
- Nov 8, 2017
- Womelsdorf
Looks like a fair amount of work…$300I found this at a job site. He’s saying $500 to $1000. The hitch is cut off so a conveyor could go under it. The predator did start and die. He’s saying $500 as is or $1000 if it runs. Is this worth the $500 as is?
It’s a pool place that did firewood over winter and beat the crap out of everything. I got a 35 ton countyline today for $200 that they left the air filter cover off and filled the engine with water. That’s things beat but the hydraulic fluid looked good. This doesn’t look like it has a ton of hours on it. It just looks like no one cared about it. The original Honda engine is sitting next to it and pulls over good. I tried to buy the Honda and he kept telling me I don’t want it.500 is probably an ok deal. Those are like 3k new. I'd check over the beam where the wedge slides for wear. It might have a ton of hours in it if it's been repowered.
Splitter and old Honda motor for $500?It’s a pool place that did firewood over winter and beat the crap out of everything. I got a 35 ton countyline today for $200 that they left the air filter cover off and filled the engine with water. That’s things beat but the hydraulic fluid looked good. This doesn’t look like it has a ton of hours on it. It just looks like no one cared about it. The original Honda engine is sitting next to it and pulls over good. I tried to buy the Honda and he kept telling me I don’t want it.
It has a log lift. He’s not giving up the old Honda for some reason.Splitter and old Honda motor for $500?
Relatively easy rebuild on a bulletproof motor.
I assume you have a welder or can otherwise add a hitch.
Is that plumbed for a lift? I see 2 sticks…
The price on the first went like this…
It already has a year old predator put on that luckily only needed fuelFor $500, I would buy it, sell the motor, and put a new one on (Honda, Kohler, or predator, whatever I could afford, it doesn't matter). The log lift alone is worth $500 imo.
I think I’ll do alright. As tractor supply tonight I saw they have 25 ton splitters for $999. I’m about $850 into these already but buying something that works the first day is too easy.$500 seems ok, you would likely pay that just for the hydraulics.
