List of saws that can be upgraded to 346xp?
davidwyby
Tree feller, axe handle breaker
4:45 AM
Extreme Southeast CA
Which is the one where you need the ?riser block/base? From a 350 to put the 346 PnC on?
I’m looking for a cheap upgradeable parts/project saw here in the southwest.
John235
7:45 AM
NH
Also 353,351, 346 are all mag case bolt on cylinder and go. While 340 345 350 are plastic case with metal riser block, which you can still get the same results just isn’t a pro saw. I have both. And having both apart the 350 style has a lot more places to fail or leak. Being an amateur it took a few tries sealing up the 350 to get it to pass the leak test. But done correctly they can be great saws to.
