Kohler command vtwin compression
idiotwithasaw
10:06 AM
Ky
How much compression should one of these have. I have a horizontal shaft vtwin that I want to check, but I don't know what it is supposed to be.
idiotwithasaw
10:06 AM
Ky
Ok guys I went ahead and tore into this thing. It was a 24 hp kohler and checked the compression, one side read 160psi the other read 40psi. did a redneck leak down test involving a airtank and my ears. To ensure the valves were closed I took off the rocker arms, determined that both valves were leaking after the test, there was an attempt to lap them but the pitting in the exhaust seat was too deep. with my lack of experience in this area i decided that it was best to go a different route.
I then took the head off of a donor engine, did a quick leak check of the valves with brake clean. Found that the intake leaked, it was then lapped and rechecked good. After all this I cleaned everything and installed the head with a new gasket and worked my way back up. After it was all back together compression in both cylinders was around 160psi. So I think that's pretty good for a rookie.
Later I will reinstall this back in the mower and get it running, when I do I will update.
jake wells
no longer here
10:06 AM
ky
did a redneck valve lapping job with me only took an hour to find a drill LOL.
bikemike
10:06 AM
Cottage grove mn
How low did you have the idle set during operation? Sometimes a really low idle will trigger the built in comp release and burn valves that Crack open for comp release. Or just had lots of hours on it
idiotwithasaw
10:06 AM
Ky
I bought this mower with the intention of fixing it. The original motor threw the rod for some reason. The engine I was working on I was given to for free. I don't know the history of either, I am new to four stroke stuff and am trying to learn. I've gotta get time to mount it back in the cub and see how it's gonna run.
idiotwithasaw
10:06 AM
Ky
Also thanks for responding any advice is welcome.
jake wells
no longer here
10:06 AM
ky
reason for the burned valves it has 3,000 + hrs on it.
idiotwithasaw
10:06 AM
Ky
There's no telling honestly. But it did run if only for a bit. I'm gonna attempt to clean the carb and maybe adjust the governor. Need to get some zip ties and organize some wires while I'm at it. I can't wait to get this beast to life.
jake wells
no longer here
10:06 AM
ky
i use trash bag ties to tidy up wiring it works and lasts longer than zip ties.
idiotwithasaw
10:06 AM
Ky
Holy cow the carb kits for these are $70 I'm gonna see if Napa can cross it and get it cheaper
