- 1:21 PM
- Jan 14, 2016
- North western Ohio
Rambling on I use that zero turn like a little tractor .For example on my ten acres I have a zillion downed small trees I cut for fire wood .The mower will fit where a tractor won't between the trees and zero turn it will turn on a dime and give you 9 cents change .,With a yard cart I can get a load in maybe 20 minutes .Pop corn dry and being small does not need split ,cut and stack .The less you have to handle fire wood the better time you will make over all . I've got two splitters .One is a home built heavy duty heavy as lead with a 5 inch cylinder that will split anything .The other is a 4" TSC I can easily move around with the mower that has a 2" ball hitch .
