K216 to k095 adapter
CoreyB
4:12 AM
South east iowa
Is there anywayto get a k095 bar to work on a k216 mounted saw. An adapter, modification anything?
Jon1212
Birch! Please.....
3:12 AM
Utah, unfortunately.....
jake wells
no longer here
4:12 AM
ky
the mount is the same you will need to grind out the tensioner holes and grind a spot for the oil to get through.
its a lot of trouble just stick to the original bar.
Jon1212
Birch! Please.....
3:12 AM
Seems easy enough. The same process is done to convert a K095 into a K041. It probably takes 5-10 minutes with a dremel.
jake wells
no longer here
4:12 AM
ky
or just buy the right bar lol.
Likesaws
5:12 AM
South west. Virginia
Unless the bars you want to run don't come in the k216 mount. If I where to get one I would like to run that Oregon speedcut light weight bar on it. And I have it already in K095.
Corey I know you have a Dolmar 421 and a 6100 both great saw and you need something to fill in the middle lol must be CAD. Be careful it's a hard thing to control.
CoreyB
4:12 AM
South east iowa
That is exactly what it is. I have yet to find a situation where the 421 and 6100 can't bring the wood home.
I really want the 301sx to come state side. Lol dang cad!
SawTroll
Information collector
11:12 AM
Troms, North Norway
Based on the attached document the K216 looks very similar to the Ko95, with the same kind of oiler holes (= "normal" oiler holes, not the same system as the K041)?
I have seen cases where the same mount from different manufacturers looks more different...
AVB
4:12 AM
Elora, TN
Does this over lay helps? Grey areas are this mis-alignments.
SawTroll
11:12 AM
Troms, North Norway
Yes, but then there is the accuracy of the drawings, and consistency in production (also between bar brands) + the exact shape of adjuster pins in relation to the holes.
To me it looks like the K216 exists only because a saw brand insisted on having "their own" mount pattern, likely to sell more of "their own" bars (sounds familiar?) - but there are other possible reasons as well.
