JONSERED Jonsereds
6:16 AM
6:16 AM
heimannm
5:16 AM
Dike, Iowa
Does anyone know if a points replacement chip like the Nova can be used to replace the trigger on a 70E?
Original part 504 62 00 17 is very hard to find and costs $90+ if you can find one.
Thanks,
Mark
NCFarmboy
6:16 AM
Hayesville, NC
Have a Jonsered 630 Super 2 on my bench. Rebuilt starter from my NOS parts stash. Next carb rebuild and fuel lines. Carb is a Tillotson HS257a. Looked it up on Tilly website. It's not listed. Found it on page 6 of my 630 IPL PN: 503-2803-15 Recirculation carburetor. Does take reg RK23/DG5HS carb. kit.
Never ran across one before. Pop off is 7 psi/.5 bar. Should it be more? I'm thinking 15 psi. Anyone know anything about this carb.?
Shep
5:16 AM
KYsawman
6:16 AM
Gone Fishing
get
Gonna slather the seam in JB weld? And what head is on it?
I tried that but didn’t work, found a used one on eBay and have it coming. The seam is leaking under the coil area by where the cylinder bolts down. There is not much room to cover the seam with sealer and not interfere with base sealing. It is stock 45cc for now, I have the riser or as husqvarna called it a bearing cup. I might just go ahead and put it in and put the 346xp top end on it too.
