Jonsereds 2255 chain conversion
Welderman85
6:23 PM
Michigan
I was just given a jonsereds 2255 saw it runs good but needs a new bar and chain. Im not sure on the cc of the saw. But it had a 20" 3/8 72dl. I allready have a few saws running 20" .325 78dl so I was thinking of swapping. Is this a dumb move. Will .325 work ok on this saw. Thanks
Shane¹
6:23 PM
Kentucky
.325 will be fine just need to change the sprocket too then you should be able to run the same chains as your other saws
