MAF143
- 6:17 PM
- Mar 30, 2021
- North Central Ohio
Another friend of a friend brought me his Jonsered 2065 with a broken chain tensioner and he wanted muffler mod also. I was busy when he dropped it off and I never started it while he was here. My mistake...
A couple days later when I got to it, I started it but it would barely idle and backfired a couple times when I tried to give it throttle. I didn't think much about it and ordered a carb kit for it and did the MM.
I started it after cleaning the carb and putting in the kit and checking the lever level. It all looked OK, but when I started it it backfired once. Then it would idle, but not take throttle. I played with the tuning some but it just doesn't respond like normal. It flooded a couple times and I had to change plugs to get it to start again.
I took the carb off and checked the metering needle valve to make sure it is seating and opening properly. It holds pressure like it should when closed.
Being a rookie at carburetor diagnosing, I'm just assuming the carb is bad and needs replaced.
Has anyone run into similar symptoms? I hate to order a carb if it could be the ignition coil or something else.
I did check the flywheel to coil gap and it was a little big so I re-set it to .012 but that made no difference.
Thanks for any suggestions.
