sefh3
- 12:18 AM
- Feb 11, 2016
- MI GO BLUE!!!!
Looks like it's scored from the carbon. Low quality of gas.
Looks like a bit of scoring on that piston. A leak down test is pretty much mandatory before you tear it down.
I'm inclined to believe it was that way when u got it,,, I agree it is carbon scoring from years of cheap fuel/mix, your two tanks through it didn't do that.....you would be surprised how well that piston will clean up!!! I need a decent used P/C if you decide to part with the old one!!!I've only had the saw for about a month now and have only run maybe 2 tanks of gas through it. I use non ethanol 91 mixed up with stihl oil at 32:1
I tune all of my saws to where they just start to 4 stroke and then they clean up in the cut@riverrat2 we must have cross posted, i didn't see your post when i wrote my last. Yes she idles well will sit there and just idle away. The last owner told me he had her tuned fat for milling so i just left her there. At some point I should probably tinker a bit with the tune.
Uh huh.Really fat.
