- 2:24 AM
- Dec 30, 2015
- Brewster, NY
Definitely not in my opinion!
I see it slightly differently. Basically if an engine is not held back it's carburretion or it's ignition, then the only (?) thing holding it back, i.e. preventing it from revving higher, is how effectively it can flow a dense charge into the CC.
For the reasons you pointed out (muffler, transfers, venturi, etc.) the engine will "run out of breath" at a particular ceiling (i.e. 14 or 15k or whatever). However, by increasing the case compression, I believe that we create a supercharging effect, enabling the system to rev somewhat higher than before.
Well that's my take on things![]()
More pressure, but less volume, it is always a balancing act. Perhaps different blow down for different case capacity???
