livemusic
- 5:54 AM
- Jan 22, 2016
- NW Louisiana, USA
I have a Husky 540iXP and now they are coming out with 542iXP. The 540 I have, I have complained about, in healthy oak, it "bogging down," too often, "getting in a bind." Like the bar/chain is getting bound in the cut somehow and it stops the saw and I have to go again but I have read all I can about this and some mention that the clutch cover presents a problem in clearing chips during the cut. Is that the same problem as I describe? Whatever it is, it's maddening to have an otherwise good saw and it does this.
My other question is... if the clutch cover is the culprit, do you know if the clutch cover for the 542 could be put on the 540 and problem solved? Or another solution? Is lack of chip clearance what this is about? I'm actually put out with Husky for releasing this saw like this, it should not be this way for an expensive saw like this to behave poorly in oak. I have lots of oaks! Husky should give me a fix! Otherwise, I really like the saw. Presently, I am thinning some woods and it's lighter than other saws I would use. Except for my Echo 2511 but the Echo doesn't have enough power for some trees. I might hop it up some, lol.
