WANTED Husqvarna 572xp or 562xp Carb Parts
Gvsu141
2:14 AM
Grand Rapids Michigan
I have a 572xp that has a bad main nozzle/check valve in the carb. I'm having a hard time finding any replacement in stock, and I refuse to buy a new $200 carb just for the nozzle.
Does anybody have a used or new main nozzle, or a parts carb laying around? I could make a one from a 562xp work as well with a slight modification. They're different from others I have laying around, and are 5mm x 7mm.
I got the parts numbers from ZAMA, but they're not expected to be in stock until Feb 26 at the earliest.
572xp uses ZAMA main nozzle part #A00700714
562xp uses ZAMA main nozzle part #A007705 or #A007705A
Gavinmalloy18
2:14 AM
Southwest Virginia
I have a used 572 carb that I replaced because the saw died idling. A new carb fixed it right up, I’d sell this one cheap plus shipping if you thought it may work
Gvsu141
2:14 AM
You are likely having the same problem I am having, so it probably won't fix the issue. My saw will also die on idle and stumble when coming down off throttle.
It seems many people are facing this same problem. I found my check valve is bad, and hoping this will fix it.
pilondav
Active OPE Member
2:14 AM
SE Michigan
I have a brand-new Walbro HD-12C that I bought in error. (I have a 372 X-Torq, not an original one.) Message me off-list if you can use it.
