species8472
- 1:13 PM
- Feb 5, 2016
- Smithton Tas Australia
Do anyone here know if this problem is on all 562s or on only some year models.
never heard that one... I have a blown one in my "to do" pile to check now.
the question is how to you correct that piston pin issue( long term) if you are getting it with OEM ?
Should we start a check list of issues to review before we buy a used 562 ?
EL 46 carby bog issue
Hot restart issue
feel free to add yours to the list:
edit...mine has a distinct line down the middle of the cyl. looks faint as in just slightly "loose" pin....
560 has different bearings compared to 562 if I understood the IPL correct, and I belive the bearings has been updated the last 2 years, at least they have updated on 545/550 so I would think it has been done to 562 since they share the same bearings as 550 has, happen on 550 from 2015 week 54.1) about 30 560 with fails in bearings .......... just bad luck ?.......... you can tell it bad luck if you want
Friend of mine has spent a lot of time analyzing 562 short falls and fixes for them, maybe he'll chime in @weimedog
