Cajunrx8
- 4:18 PM
- Aug 12, 2018
- baton rouge la
I have a problem that so far I have not found a solution to, I am replacing crankshaft seals on a 55 rancher.
I made a homemade tool to pull the worm gear off of the clutch side shaft and changed seal, there is no step on the shaft to
locate the gear depth, it is straight from the case bearing all the way to the clutch bearing step.
I didn't think to measure the gear depth before removal. The shop manual says to press against the shoulder of the crank but
I don't have a shoulder, the gear can be pressed all the way into the seal.
Can anyone measure the shaft and tell me how far the gear needs to be pressed?
Thanks in advance, Steve K.
