Husqvarna 55 oiler
Motorka
5:21 PM
EU
Ma sexond husqvarna 55. Liked it but it s begin to use less than half tank of oil . Did clean rubber hoses and everything looks ok. Any idea ?
cus_deluxe
terms of service violator
11:21 AM
Michigan
ive “fixed” more than one oil pump by spinning it the other way by hand with the normal outlet submerged in oil so its sucking instead. forces out any little stuff stuck in on the other side.
dangerousatom
11:21 AM
Quakertown, PA, United States
Check the steel pump/plunger that is spun by the worm gear. If its worn were it fits into the rubber/silicone oil feed or that black rubber housing it goes into is worn or torn it will not push as much as it should. Any spot in the system that loosed "seal" before getting to the bar will drop flow or out right leak. Did you check/clean the brass cage filter in the oil reservoir too?
Have you changed oil brand? Not all bar oil is the same viscosity, too heavy or lite and it will vary output or not push anything.
Motorka
5:21 PM
EU
Huh, probably was the oil. Another brand ...
