furb
- 1:31 AM
- Nov 8, 2017
- Womelsdorf
The 51 was run with the brake on so it needs everything from the bearing out I assume. It got hot enough to take the spring out of the spring. The 55 had something wrong with the throttle linkage and had parts robbed from it. They both have good compression. Can go parts or whole. If you want to 51 to fix I can take parts from the 55 to fix the 51.
