Husqvarna 450 won't start
Gentleman
5:21 AM
Daytona Beach, Florida
We have this saw that a customer brought in. 6 months old won't start. We have checked everything on this saw and can't figure it out.
Compression, vacuum/ pressure test, fuel line, intake manifold, impulse, spark all good. Just put a new carb on it and still nothing.
Anyone seen this before?
5:21 AM
Will it pop with fuel down carb throat? New plug?
Simondo
10:21 AM
UK
Wet plug?? ...dry plug?? ...no pop at all or a pop and then still wont run??
Chainsaw Jim
Con Artist LLC
2:21 AM
Springfield Oregon
Usually when I come across this it's either something wrong with the air filter or a broken torsion spring inside the spark plug boot. Then there's the bad ignition system which is a little less common in my experience.
Disciple of Monkey's
4:21 AM
Yes, a component in the module inside the coil gives out and the spark you see is not powerful enough to spark under compression and the engine will not run.
Gentleman
5:21 AM
Also seen coils show good spark, but will not crank or run correctly. Did you put a new fuel filter in?
We first thought the coil so we swapped one off a new saw just to try.
Did not change the fuel filter. I'll try it. I hope it is something that simple.
Terry Syd
7:21 PM
Comboyne, NSW Australia
My modified 450 is the most reliable starter of the bunch. Three pulls with the choke, maybe four, and the engine comes to life.
I had a problem with the fuel primer when I first got it. It used to flood the engine. The pressure in the tank would over fuel the wet side of the carb. I ended up blocking it off. No more problems after that.
Veljko
11:21 AM
I have problem like that.They have put fuel line in wrong order on primer.
merc_man
merc_man
5:21 AM
southern ontario
Pull plug and dry out.with compressed air.
