ELECT6845
- 11:19 PM
- Dec 28, 2015
- INDIANA
Let me take a minute to tell you about this one as it has some issues. First lets start with the good. Compression is 162 and it starts right up. The issues are as follows
On/off switch doesn't work
Flange around the exhaust bolt is wallered out and you have to pry a screw driver in it to loosen or tighten the nut.
The bottom felling spike bolt is drilled thru the oil tank and is bolted thru. There is a piece of rubber behind the spike to keep it from leaking.
Tank has a patch on the bottom but I will included a used tank
Clutch cover has some cracks and the lever needs attached. Extra cover included
Starter cover has a piece missing at the top and a long screw and washer holding it on.
I think that's it.
What's it worth ???
I think that's it.
What's it worth ???
