Husqvarna 395xp
redoakman
7:26 AM
Canada Ontario
hey guys , quick question, is there a washer that goes behind the oil worm gear on a huqvarna 395. I'm pretty positive I took one off when I rebuild the saw and I can't seem to find it. Not sure if I'm losing my mind or not. If so what does it look like. If there is one what is the part # .
thanks brandon
PA Dan
FYD
7:26 AM
White Oak PA
thanks brandon
Yes there is.
PA Dan
FYD
7:26 AM
White Oak PA
Here ya go
jacob j.
Only the weird
4:26 AM
Coastal Oregon
it wouldnt happen to be same one as the 372 ?
They're not the same. The washer for the 372 rides on a separate bushing that slides over the crank. The washer for the 395 rides directly on the
crank and stops at the stub shaft shoulder just above the main bearing. The two washers have completely different dimensions.
redoakman
7:26 AM
Canada Ontario
you wouldnt happen to no dimensions of the 395 one? i am in canada and dont have a very close dealer and cant find one online
jacob j.
Only the weird
4:26 AM
Coastal Oregon
I don't know the dimensions offhand, but you don't want to throw any old washer in there. This is a thrust washer, hardened and made for axial loading.
redoakman
7:26 AM
Canada Ontario
