coryj
- 4:37 AM
- Jun 30, 2017
- Charlottesville, VA
I picked this up locally back in June. I haven't had much opportunity to run it since I picked it up. In all honesty, it's bigger than what I need. I've run it for maybe an hour. It starts easy and everything functions as it should. I don't have a picture, but can get one, the piston looks good through the exhaust port.
It's wearing a 36" bar 404 .063 full comp chain.
AM clutch cover/chainbrake. Hightop air filter, west coast felling spikes. I replaced the cylinder cover with a used OEM piece, but you can see the variation in orange.
I'm mainly considering firearm trades at this time. I like 16 gauges, side by sides and semi-auto shotguns with wood stocks. With that said I will consider any firearms trades. My FFL accepts from individuals so you can ship direct to him using your preferred carrier.
I'll let the pictures tell the tale.
The cylinder cover had narrow clips, the air filter cover had wide clips, but it works. One is missing on the back as pictured below.
