Husqvarna 394 case repairs, welding.
srcarr52
6:23 AM
Iowa City
I fixed a bunch of 394/5 cases, one in particular was pretty badly damaged but turned out really well so I thought I would share it.
A large chunk of the case is broke off including the upper starter asm mount, carb shelf and rear left AV mount.
Welded up!
rocketnorton
3:23 AM
surrey, bc, can
what's a job like that worth to you. 394 case?
recently did one, makin one good case from 2 broke ones. was remington, unobtainium.
lotta cuttin n grinding to make pieces fit.
turned out pretty nice, tho.
even after knocking some time off, wondering if i over charged...
srcarr52
6:23 AM
Iowa City
Yes, it was a 394 case.
It would probably around $75 to weld the case back together and make it all pretty again but this was for a friends saw that I'm building him so it was no extra charge. I've been told that I don't charge enough.
jacob j.
Only the weird
3:23 AM
Coastal Oregon
Try bringing him donuts and/or beer next time. He’ll weld it.
Actually, I took him a couple crabs last time. He's not a drinker and doesn't have a sweet tooth - but most people here on the coast like crab.
In fact some of the local businesses will barter in crab and rockfish.
hseII
Heef
6:23 AM
West Georgia
Welded up!
View attachment 171031 View attachment 171032 View attachment 171033
Shaun,
Is that with a spool gun?
Little 1-2 lb spool Like we can do with Aluminum?
srcarr52
6:23 AM
Iowa City
There are really only two rod alloys readily available. AZ92A and AZ61A, on dirty old cases I can’t really tell the difference.
You set the tig welder on AC with setting similar to welding aluminum. Cleaning and prep is everything.
hseII
Heef
6:23 AM
West Georgia
Nice!!
rocketnorton
3:23 AM
surrey, bc, can
+1
might add that "cleaning" w/fiber grinder wheels leaves chit embedded in base metal, contaminating weld.
carbide burrs/die grinder is cleaner. or wire brush...
my rate is $50./hr., btw.
