- 6:25 PM
- Jan 12, 2016
- Iowa City
what's a job like that worth to you. 394 case?
Try bringing him donuts and/or beer next time. He’ll weld it.Plus my local guy won't do saw cases anymore - he hates welding Mag.
I fixed a bunch of 394/5 cases, one in particular was pretty badly damaged but turned out really well so I thought I would share it.
A large chunk of the case is broke off including the upper starter asm mount, carb shelf and rear left AV mount.
Welded up!
View attachment 171031 View attachment 171032 View attachment 171033
Shaun,
Is that with a spool gun?
Little 1-2 lb spool Like we can do with Aluminum?
Nope, it’s tig welded with magnesium filler.
What rod ?Nope, it’s tig welded with magnesium filler.
There are really only two rod alloys readily available. AZ92A and AZ61A, on dirty old cases I can’t really tell the difference.
You set the tig welder on AC with setting similar to welding aluminum. Cleaning and prep is everything.
Nice!!
