FOUND IT Husqvarna 346XP project
Sleeper
10:57 PM
United States
To be exact, looking for one that needs a top end and maybe carb rebuild... muffler or other small things... nothing more major than that... lower case, bearings, seals, and crank/rod need to be good.
This will be a saw for my dad, who occasionally likes to help me with firewood, but doesn't want a heavy saw. Willing to spend around $250 tops for a good to great looking one with a bad p/c. I'm thinking it will be a Christmas present for him.
Obviously, it would probably be in the box you send it in when Christmas comes by, since I already have two projects going, but it likely will be done by spring.
One of the projects taking up bench space really doesn't need much.
Thanks
Sleeper
10:57 PM
United States
Is that saw all OEM? As in OEM coil, p/c, cases?
Sleeper
10:57 PM
United States
Hit me with a PM with more pictures of it... and if it doesn't bother you, would like one of the piston through the exhaust port. And/or let me know where in MI you are, if you're close enough, I will just come over and see it in person. Usually saws looks better in person, anyways. Interested in buying from another Michigander.
Mattyo
Youtube speciawist
10:57 PM
Farmington, CT
Sleeper...got u covered for a rebuild vid if you need it...including splitting the case iirc. check my youtube channel.
Don't sweat a full teardown :)
Gary Courtney
9:57 PM
Froglevel
I have 2 i rebuilt from top to bottom 100% oem all the way. 15 minute runtime on each . one with primer both 50cc p/c if interested
