- 11:05 AM
- Jun 5, 2016
- Northwoods of Wisconsin
No and don't know.Did anyone try the foggy sail fix on it? Do the flywheel fans bolt on the 285s like the dolmars?
No, 2100's have the SEM CD and the 285 has the Bosch.It the same as a 2100 ?
Am going to try that if the coil is still good, but still looking for a replacement.Did anyone try the foggy sail fix on it?
Actually the 2100 could have either the Bosch or the SEM ignition, as well as one other, the name of which escapes me right now. Each required the flywheel unique to that unit, and there were two pawl starters on some, three pawl on others. It ain't simple.No, 2100's have the SEM CD and the 285 has the Bosch.
Thank you, that is it. I couldn't get the pic I was sent to upload.Should look like this.
the other coil was{perfex}Actually the 2100 could have either the Bosch or the SEM ignition, as well as one other, the name of which escapes me right now. Each required the flywheel unique to that unit, and there were two pawl starters on some, three pawl on others. It ain't simple.
I'll check today and see if I have a spare Bosch unit.
