SOLD Husqvarna 262XPG
295 tramp
Hillbilly Saws
7:38 PM
Minnesota
I'm putting this back up for sale. I pulled it last time because saw weren't moving.
The saw was completely tore down except the case and crank. I gave it a new meteor piston, caber rings, pin, bearing, seals, carb kit, It has the HDA 120, new base gasket, bar guide plate, chain catcher, I opened up the muffler from the inside at the stock location. and all the components for the G option. Pressure and vac tested. There is a nut to keep the chain catcher secure and a heli coil or insert on the starter right top It's pushing 160 PSI and has only 1/2 tank thru it so far for the break in. It is set rich for the break in. PHO 375.00 plus all shipping
20160114_185352.jpg 20160114_185433.jpg 20160114_185411.jpg 20160114_185449.jpg 20160114_185505.jpg
zero_sum
8:38 PM
Vermont
2nd in line. I'm not sure how I missed this before.....
