calebng15
- 3:42 AM
- Feb 14, 2016
- Butte, MT
Ok, the 61 is headed to Texas. To @Double J Creations . 261 is still available!
Does the 261 have an 'A' or B cylinder? HaOk, the 61 is headed to Texas. To @Double J Creations . 261 is still available!
Received the saw today, I removed covers just to look at things, does have the two piece ignition. Installed the bar and chain. I filed the chain lube reservoir. Did not run it yet as I need to buy some Husky TC oil maybe tomorrow. Looks to be in good condition, chain looks new, here are some photos. Thanks Caleb.View attachment 18872View attachment 18873 View attachment 18874 has good compression and spark. View attachment 18871
Hello Caleb, used the saw this weekend, it's awesome.
I need to ask a question about another 61 I have, am repairing it, just installed a new two piece ignition in it, still not getting any spark. Any ideas as what could be wrong?
Or should I create another thread and get others opinions.
Yes set the gap, I will try to set it up closer to the flywheel, but the coil has slots the mounting screws go through that are at the end of there travel so might not be the problem. I'm wondering if the gray wire that connects to the kill switch should be grounded, in other words the kill switch should be in the on position and not in the off position, the way I have it now. Although many I have seen need to be in the off position in order for the coil to spark the spark plug, with this two part ignition it could be just the opposite. I'll try this out tonight to see if this is so or not and let you know, thanks.Have you set your gap?
