SOLD Husqvarna 261/262xp
NorthcentralYooper
2:37 AM
Upper michigan
I'm selling this really nice 261 converted to 262xp. Still has 2 puck clutch though.
It's got a meteor piston , new bearing, new worm gear, new sprocket, new oregon fuel line and filter.new tank breather, New brake band, new plug, mahle cylinder was bead blasted and looks like new, casting marks removed and smoothed out is all. Muffler bead blasted ported and painted in ceramic header paint, thin gasket for .019" squish. 144 carb is almost new , limiters trimmed.
Saw case was refinished and clear coated. Case was not split and bearings had zero play . Crank seals replaced.
Most parts all OEM. This was a clean running saw prior to I just went overboard in replacing parts even when not needed, cylinder had cross hatching still.
If you want more pictures contact me.
I ran one tank through it. I will check compression later after it cools.
I got a lot into this saw, I was building for myself but had third child and other needs so I'm selling. .
Selling PHO asking $350 shipped PayPal FF to lower 48. I've sold on here 2 times before
