Quzick
Santas little S*itler...
- 3:01 PM
- Nov 7, 2017
- Baltic states, Europe Union
So, as the metal bearing cover is NLA and the plastic ones are leaking like hell due heat warping.
Solution is simple.
Just replace the flywheel side mainbearing with 503252501/525434201 etc. Like used in 346xp/353/550xp/560xp/562xp
Those washers are for installing the bearing in place.
And moment later...
And then:
Grind/Mill the plastic cover flat.
And reuse the cover, otherwise you will have even worse leakage then before.
Solution is simple.
And moment later...
And then:
