300whisper
- 2:37 AM
- Aug 28, 2022
- Finland
Asking for help because my desperation is getting biblical levels. I’m struggling with my neighbors Husky 242xp, which he got for free after some tree felling project and gave it to me to make it run again.
Saw was missing cylinder cover and everything between intake and trigger mechanism. Parts were relatively easy to find because this saw is/ was widely used in my neck of the woods.
Carburetor was completely disassembled and cleaned in ultrasonic, not once but twice, assembly with new carb kit. First assembly was with some aftermarket kit and I didn’t get saw running well. Luckily I found new kits from local saw shop and bought plenty for rainy day.
Cylinder was in relatively good shape. Piston had slight scoring marks, nothing catastrophic. Piston ring was way past its expiration date, so I got new Caber ring.
Measured squish w/o gasket, .013”, too tight for my taste, so I decided to make new gasket because neighbor wants reliable and easy to start saw.
After through inspection of crank seals (looked ok), bearings and cylinder I made pressure and vacuum test, passed flying colors. So far so good.
First start was around the corner after replacing new fuel filter and everything was good to go.
Saw was idling nicely with basic settings (L 1 1/2, H 1 1/4), after some small adjustments idle was 2650 rpm and WOT 13500 rpm. Cut few cookies and returned saw to my neighbor who was more than satisfied despite this project took more than 4 weeks to get parts.
Fast forward to last Sunday. Neighbor called and told me saw isn’t idling correctly and starts to rev up when saw is tilted to felling position. Ok, I’ll take a look and see what is the problem.
Couple of days ago I changed new crank seals and found out flywheel side was ”dry” and had some carbon deposits around the seal pocket. i thought this might be the problem despite the fact saw passed pressure and vacuum test. Maybe new gas and running made this seal to give up.
This morning I finally had some time to look it again. Got the saw running but same damn issue, tilting to sideways gets rpm up around 5- 600 rpm and chain starts to move. Back upright position makes it run normal idle speed. WTF?
Please note, I’m not small engine mechanic but I understand 2 stroke engine working principals. I have built almost all my chainsaws and have never experienced anything like this.
Saw is on my bench carb open, gaskets inspected, everything looks ok but I can’t get this damn saw running right.
Is this carb issue or what?
Thank you in advance.
