SOHC
- 12:26 PM
- Sep 17, 2023
- Newzealand
Hello I put together a Husqvarna 2100cd and when i installed the clutch side main bearing I used an old oil pump as a stop to set the location of the main bearing, heated the crankcase and dropped the bearing in, but when i put the oil pump on it wouldn't turn when i tightend the screws. I think the oil pump needs to pull up on the bearing and not the engine case it self? I took apart another saw and measured it and the oil pump and found this was set like that
