FOUND IT Husqvarna 1100 Recoil Cover
Warped5
2:13 PM
Northwest IN
I don't need anything but the cover. If the ferrule is in there, that's ok.
Unsure as to which other covers will swap in ... this one takes the thick plastic air shroud under it, not the thin metal one like a 2100.
Not needing a beauty queen, either ....
Thanks!
Eccentric
Yes, we do have trees in Wyoming.
1:13 PM
Northwestern Wyoming
What happened to the 1100?
Sorry I haven't returned your call yet. Been a rough/busy week. Gotta work Saturday, so I'll either ring you on the way in or will call Sun or Mon when I'm off if that's OK.
Warped5
2:13 PM
Northwest IN
Area around the bottom screw hole broke off when I was starting it yesterday. May have already been cracked. Not happy about it. May have to rig up a temp fix with some bent up washers or something.
OK on the phone call. Will be cutting/splitting today, so Sunday/Monday is probably the better option.
jacob j.
Only the weird
12:13 PM
Coastal Oregon
Ted- which ignition does your saw have?
Warped5
2:13 PM
Northwest IN
Here you go, JJ .... no discernable marks on the flywheel. No further way of knowing here unless I pull the flywheel.
Morningman
Active OPE Member
12:13 PM
Here's a cover all holes good
Morningman
Active OPE Member
12:13 PM
Inside
Warped5
2:13 PM
Northwest IN
Here's the one off my saw. Note how the recoil spool is for two pawls and the exposed rope ferrule ....
jacob j.
Only the weird
12:13 PM
Coastal Oregon
I founded a replacement in good shape...
