RIDE-RED 350r
- 11:03 AM
- Feb 8, 2016
- Blossvale NY
Ok, so awhile back I did an overhaul on a dead 359 I picked up on the cheap. Part of my overhaul routine is to replace fuel line, filter, and tank vent. This particular saw had the large vent puck. I know some saws came with a smaller vent puck that seats deeper into the vent port on the tank.
So, the issue is that the darn thing leaks fuel when the saw is laid on it's side. This is not the first time I have come across this. I checked the vent port visually for damage and it looked fine and the new puck seemed to pop into place as it should. I have noticed that the small pucks seem to seat a bit more snug though. So here is what I am wondering, can a small puck be used instead of the large puck?? Can both be used simultaneously to ensure against leaks? Or would either arrangement not allow the tank to vent properly?? The only model I have come across with the small puck at this point is a 346XP/OE. Makes me wonder if the fuel demand of the larger displacement saws require the larger puck???
It's an annoying issue, and I'd like to try to rectify it..
