Nc grease monkey
- 9:46 PM
- Oct 25, 2017
- Boone, nc
Pile of huskies missing odds and ends.
Husky 61 mahle cylinder tillotson carb missing flywheel, clutch, chain adjuster, other parts im sure, part of casing broke of right below chain adjuster
Husky white top 65 mahle cylinder tillotson carb missing gas cap, clutch, coil, air filter, fuel line, etc etc
262xp ks jug and piston walbro hda87 carb, piston rough on exhaust side, cylinder cleaned up good and ordered meteor piston
372 xp x torque (cylinder and piston look barely used) need handle bar, muffler
575xp bad crank bearings, gas tank busted, crank case has small crack
My question is, are the 61,65 and 575 worth fixing? I've never used a husky saw so don't know much about them, only what I google. The 372 and 262 are supposed to be great saws, the other 3 not sure on. Any info or insight is appreciated.
