- 3:43 PM
- Nov 6, 2019
- Salem, Missouri
Ok, so to start I'm a Stihl or Dolmar guy. I've built and/or modified literally hundreds of them over the years. I of course have build a handful of husky saws but just a few. Mostly 268/272, 372, and 385/390. In general I try to stay away from them unless it for a friend. Their just foreign to me I guess.....and then today it happened. It finally happened. I knew this day would come eventually and it finally has....a husky came my way and seemed like to good of a deal to pass on.
The saw is a 576xp Xtorq. I ended up picking it up for a little under 200 bucks. I bought it assuming it didn't run and would need enough repairs that I'd just part it out. So I get it into the shoo and find it has great compression. Pull the muffler and the piston looks great. I dumped a little mix gas in the cylinder and a new sparkplug and it fired right up. The crank bearings feel tight and it's at least mostly complete. So I guess I'm going to try my hand at building a husky and who knows maybe I'll even hang onto it a while.
The issue is I don't know ANYTHING about these saws. I don't know what all is miss or should be there. Right out of the gate I can see it's missing....
-fuel filter
-air filter
-Clutch side cover
And the muffler is beat to death.
What are the common failure points on these saws?? I've always heard horror stories about crank bearings.
Also does anyone know where to find any used OEM parts??
Does anyone have a parts diagram of the saw??
I appreciate any help you fellas may have to offer.
-fuel filter
-air filter
-Clutch side cover
