Husky 55 AV rubbers removal, help
Woodwackr
10:03 PM
ID
So, am disassembling a later 55Rancher and can’t get the damn AV rubbers out to separate the case from the tank. Is there some sort of trick? Tired of scratching paint and bending screwdrivers.
timg
12:03 AM
Keystone State West
Dumb answer time. Do you have the two screw plastic caps pulled on the rear of the saw and the isolator plugs pulled from behind them?
Woodwackr
10:03 PM
ID
Duh…needle-nose plyers
Never mind 🤪
Woodwackr
10:03 PM
ID
These are just rubber plugs. First time doing this type :p
timg
12:03 AM
Keystone State West
Yes, If I remember correctly 4 of one. Size and two smallers. You can get different durometers though.
timg
12:03 AM
Keystone State West
This is an 06 and earlier saw correct?
Agrarian
12:03 AM
New Hampshire
Yes, I've found that needle nose pliers or channel-locks work well. Grab onto the lip and wiggle the rear handle to get them started.
timg
12:03 AM
Keystone State West
I mights have some at home I can maybe post later. Definite 51,55 series. The rear two are covered by a square plastic two screw cove that is NLA it has a plastic locator pin in the middle.
timg
12:03 AM
Keystone State West
Here is a picture of the plugs I got off the bay. It also shows the cover. I maybe wrong on the extra two and definitetly could be thinking the 272,625,620,670 chassis. Thx for clearing this up @ Agrarian. Much appreciated.
Woodwackr
10:03 PM
ID
Nope, all rubber. This is a later model 55. Perhaps the early ones have what you describe?
Motorka
5:03 AM
EU
This is the easiest saw to work on. Mounts are just pushed in. All for same size.
Woodwackr
10:03 PM
ID
Getting them in is easy, out, not so much, especially not knowing their construction :p
Now, to make the removal tool for the worm gear 😁
Nos...
Motorka
5:03 AM
EU
Done on two with no problems.
