bertfixessome
- 7:39 PM
- Jul 20, 2019
- Australia
Got a 345 in the shop
Piston broke up so I fitted a new cylinder, piston& bearings .
It runs like a champ but no oil to the bar
So far
1) replaced the spindle ( no change )
2) removed filter - not clogged
3) pressurized oil tan , oil oozes out of pump
4) replace entire pump , worm gear & rubber seal, still no oil
All parts were oiled before assembly
checked the worm is turning when the clutch drum is rotated by hand
The only non standard thing is the drum which is now a rim drive rather than a spur sprocket
Never had this problem when changing sprocket styles before
Any ideas ?
Cause I am out of them .
So far
Any ideas ?
