Husky 181 lean after the cut???
Brewz
6:04 PM
Hunter Valley - Australia
Hey folks
After a bit of opinion on this ported 181 I have built.
Basic woods port with single ring Hyway 281 piston, gasket delete, dual port muffler and a bit of a timing advance.
Its got a lot of compression, throwing it down struggles to turn it over to drop start it. Need to check it.
Stock carb with the flood limiter defeated.
It comes out of the cut a bit lean then idles fine.
4 stroking in the high 13000's
Cuts really strong. Last few cuts in the video I am struggling to keep the dogs off the log, which is dry 10000+ Janka Aussie hardwood.
I have not come across this problem before.
I'm worried that with the flood limiter defeated, the stock jets don't have the capacity to feed it at high revs now its ported.
What do people recon?
XP_Slinger
They’re Just Saws
2:04 AM
Central NY
Richening the low jet didn't help it any? I would retune the low side. Could be out of balance between the throttle stop and mixture setting. If you've already done that I'd be looking for a leaky intake or carb mount.
Did you put new seals in the bottom end?
2:04 AM
How much rpm does it lean out by ? Most my saws lean out say maybe 200 or so rpm after very long cuts getting hot. I'm no expert but maybe carb doesn't supply enough fuel for the extra need the saw has after porting? That's what it sounds like. Does it keep leaning out after the second adjustment? If not then I'd just chalk it up as getting hotter which seems to be normal with a lot of saws.
srcarr52
2:04 AM
Iowa City
The little race bike surges as it returns to idle is pretty normal for ported saws, it's not going to hurt it.
If you really want to get rid of it, I would suggest lowering the pop off pressure a little by nipping the extra winds on the spring and make sure the metering lever is set as high as possible.
XP_Slinger
They’re Just Saws
2:04 AM
Central NY
If none of the above work and your seals are in fact good I would back off the no load tune by 200rpm or so to compensate for the in the cut heat. She might just be tuned a little high.
XP_Slinger
They’re Just Saws
2:04 AM
Central NY
I'm wondering if it's timing.
^^this is a very good thought.
If you advanced timing too much what you think is a 4 strokin sound could be a timing burble. Hard to tell without being right there next to ya while piss revving.
Simondo
7:04 AM
UK
Hey folks
If your sure the vac/ pressure and tune is good then I wouldn't worry. The Dolmar 9010 sounds similar when hot and being used as your showing in your Vid.
Normzilla
11:04 PM
Cazadero CA
Thanks amigo. Yeah puzzling indeed. But possible
Brewz
6:04 PM
I was thinking last night I might try raising the metering lever a bit to try and keep a bit more fuel up to it
Will give that a go.
Will also fatten it up a bit
t4driller
Daddy Day Care
2:04 AM
Southwest pa
Does it only do it after a long cut? Maybe the tank vent is partially plugged or just not allowing enough air in causing it to go lean. Like on the husky 346 after you port them. Just a thought.
Brewz
6:04 PM
Very good point
Will check that
Chainsaw Jim
Con Artist LLC
11:04 PM
Springfield Oregon
Raising the metering lever will actually cause that lean high revving even worse. The advise that srcarr52 gave you is the procedure for your idea. The rest of that procedure would be to mod the carb so it will let extra fuel flow to match what you did to the saw. The flood limiter isn't used to prevent loading up lean, it floods the motor at a certain rpm to prevent over revving.
Brewz
6:04 PM
I noticed it sounded a little worse towards the end. You might check the intake block and carb mating surface for resurfacing. The blocks warp and some carbs aren't finished properly from the factory.
I will give them all a bit of sealant too
srcarr52
2:04 AM
Iowa City
Raising the metering lever usually yields a 2-3 psi pop off pressure change so I don't see how it would make it worse.
Chainsaw Jim
Con Artist LLC
11:04 PM
Springfield Oregon
It lets the metering diaphragm hold the lever open sooner than it's supposed to which will cause a high idle and will have that long comedown after revving.
