How would you try and save this coil
mirage
4:05 AM
idaho
I got a old Titan chainsaw that I am working on. Piston is stuck . Working on that. Got the ignition off the saw . The coil has cracks in it. Is there any trick stuff that I can coat it with. I don't know if the coil is any good. How about cleaning it before I try to coat it with anything?AF32CB87-BB15-4979-8B10-95CBA666BE20.jpegAF32CB87-BB15-4979-8B10-95CBA666BE20.jpeg 182CF58A-0368-48FB-B76E-E7590EC36393.jpeg
5:05 AM
I think I've seen @sawnami post some old coil tricks.
mirage
4:05 AM
idaho
Maybe he will point me to the info
mirage
4:05 AM
idaho
Chief Cat Herder
5:05 AM
I have coated a few with JB Weld, it has sealed them up good, kept out moisture and they are still making spark 7 -8 years later.
How would you degrease it Jerry? I've been thinking about a good way to do that, but haven't really come up with anything.
rogue60
8:05 PM
AU
I've used Araldite and tried fiberglass resin on it's own without the fiberglass on old coils like this.
Both have worked good for what I was doing sealing up and old coils the resin seemed to handle heat better than the Araldite.
Is there something better? probably that's just what I've used before.
As for cleaning that's the easy part if you don't have a can of this on the shelf somethings wrong lol
beaglebriar
The Peanut Gallery
6:05 AM
Warren Center, PA
Flammable brake cleaner would be my go to for cleaning it up. Then I'd try coating with Seal-All, it's pretty good stuff.
Basher
7:05 AM
Canada
I used brake cleaner on mine, gave er a very good and heavy dousing, let the contamination run out of the cracks, put the coil in a little toaster oven and heated it for a half hour, then applied the JB. Old Pioneer coils were notorious for cracking on the NU17, 400, 450 and some of the bigger cube saws.
Larry B
6:05 AM
SW ohio
I would clean the coil with brake kleen and dry well and then use an acrylic conformal coating spray.
mirage
4:05 AM
idaho
I think I like the electrical tape. Looks like it will go into the cracks.
mirage
4:05 AM
idaho
If the coil is bad, then you can likely find a place that will re-wind it for you. I used to re-wind various bike coils to give a bit more juice for starting. Sometimes just 10% more wire on the coil would make a huge difference.
To re-wind the coil don't you have to brake the outer shell off ? If you do do they just dip it in some type of compound?
