Redfin
Meh...
- 2:12 AM
- Dec 24, 2015
- Central Pa
Me thinks you missed Kevvys point.My fartin fas chains all have glint.![]()
Nothing looks wrong in that pic, except you haven’t dug your tunnell yet
No sweat...I'll take all the criticism you wanna give. I'm listening. But what's glint?Luv ya man but that top pic has glint, corner too low..but better than too high.
This goin on the Dragon Lee 046?
He’s not going for durability
I've dug tunnel, just a little. Last thing I want to do is break a toof. I don't have a spinner to fix.
Start at 20No sweat...I'll take all the criticism you wanna give. I'm listening. But what's glint?
Yessir...is there something about it so far that says I shouldn't?
If it makes one cut halfway straight I'll be amused. I'm envisioning a slow ass cut on a half moon curve.
Mind if I ask...why doggie bone the tie strap on the cutter but not take the chassis down just as low on the cutter side?
About what are you guys setting rakers at on go fast chains...I know wood and saws matter...but generally...where do you start? I believe the cants in Tennessee will be of the pine variety.
Start at 20
Half assed yes.Did you use a gauge?
One of mine looked like that, with the undercut sort of look. Not quite so much but I dressed a blue wheel and just touched up the corner enough. Enough to make that corner good for milling
The other side came out close to the same, even tho the lighting doesn't show it off as well.
Will dress the wheel a bit thinner before taking on the 185 dl loop for milling the burl, and taking a couple wheels down to moparnut88 & bring some smaller bars to make a board or two with him.Right on, chain looks nice.I didn't.![]()
Nope, that will cut just fine on that saw. Sort your guides one swipe at a time.Yessir...is there something about it so far that says I shouldn't?
Don't need no stinking spinner! I have a cannon ball anvil w/ ballpeen to set the rivet. Thanks for reminding me to dig out the spinner in case someone wants to purchase one at discount.I've dug tunnel, just a little. Last thing I want to do is break a toof. I don't have a spinner to fix.
Is it a name brand spinner? I got one of the harbor freight ones and it works but quality is always preferred.Don't need no stinking spinner! I have a cannon ball anvil w/ ballpeen to set the rivet. Thanks for reminding me to dig out the spinner in case someone wants to purchase one at discount.
I have one older Oregon spinner and one newer no name. They work about the same. Two punches to. One Oregon old style and one old no name. Both work good. The Oregon breaks tips.Is it a name brand spinner? I got one of the harbor freight ones and it works but quality is always preferred.
The hf one works only problems I'm having is the piece that spins again the rivet wobbles around while spinning.I have one older Oregon spinner and one newer no name. They work about the same. Two punches to. One Oregon old style and one old no name. Both work good. The Oregon breaks tips.
