How to remove clutch if nut is stripped stihl 038
Wolfnw
7:50 PM
Got a new saw today and started to break it down and got to the clutch and the nut is stripped. What’s the best way going about removing it?
Ketchup
Epoxy member
8:50 PM
Colorado
Do you have a photo? Sometimes a Husky clutch tool will fit on older Stihls.
You can also try filing the hex head down to 12mm.
Your threads are probably seized. Deep Creep, acetone/ATF, and patience. Supercooling the crank can help too. (Try an upside down can of Super Duster or Canned Air. It should drip liquid nitrogen when triggered.)
Wonkydonkey
Plastic member
3:50 AM
Sussex, UK.
Do you have a photo
yeh photos help, someone could have been doing it up when they were trying to undo it.. ?
iirc it’s a std stihl clutch.. the worst case is pull the springs out and the shoes then you could fashion something up to fit , ie an angle grinder style removal tool.
edited to try and fix fubbarded quote :risas3:
Wolfnw
7:50 PM
I’ll get some pics when I get home from work. It’s not stripped terrible but I defiantly didn’t want ti make it any worse. I was kinda thinking about filing it down to a 12. Just for a second thought about welding a old socket to it hahah but all that heat would probably cause lots of problems.
Duce
10:50 PM
Roscommon, MI
See that clutch is wide between pads, how about a plate with three studs or hardened bolts through holes, then weld a socket or head of bolt to plate and spin it off. Make a spanner type tool, drill different holes and could move bolts around to fit clutch openings. Wait I might patent that.
Ketchup
Epoxy member
8:50 PM
Colorado
I would try hacking up a socket before filing down to 12mm. A socket is nice because you can put it on an impact. Filing is a slow process and not hard to mess up. I would also do my best to free the threads first. I would be willing to bet that’s why the clutch is stripped.
10:50 PM
That damned short nut head I think Stihl made it to round off on purpose --azz holes .You take a box end wrench or a socket and notice the end has a slight chamfer with a little stubby thing like that it can't gain purchase .What I've done is used a belt sander and grind the end perfectly flat then it will hold .Six point now not a 12 point . Don't forget that thing is a left hand thread
Woodslasher
Teh debil
7:50 PM
Commiefornia
I use a very robust scrench and a cheater pipe for that exact reason, the screnches don't have chamfers on them.
qurotro
Cookie Cutter
9:50 PM
Ar
Yes. The 19mm socket has a chamfer. Probably only half of the nut is engaged. I used angle grinder to grind one flat to let it engage the whole nut. Works alright.
10:50 PM
I don't remember exactly the size but more than likely somebody could have used a 12 point socket .Didn't know any better I'd imagine .What could also work is a surface drive socket that grips the flats and not the corner like 6 point .You'd probably need to flatted it out so the whole thing could gain purchase . Worse case would be pecking it loose with a center punch an a BF hammer .Clutches don't fetch that much on flea bay
Wolfnw
7:50 PM
Luckily it’s not totally rounded off. I’m gonna try a few things you guys have mentioned tonight and hopefully I can get it off easily. Was thinking about drilling two holes like a angle grinder has for taking grinding wheel off. It’s a 038 with done be Ace Morgan with a 046 carb and velocity stack. Gonna get it cleaned up and take a look at the cylinder and port numbers. I’m super curious what’s done to it. I bought it almost 2 years ago and never ran it. Just recently got into saws and porting so at the time I bought it I didn’t even know what “Ace Morgan” meant, but pretty cool to hear some of things one hear about him and his work
10:50 PM
If you look at the first picture you'll see a notch .Somebody drove it on with a flat chisel at one time or another .
Partner
4:50 AM
Poland
well, unfortunately, some people are throwing with whatever they can ;-)
or whatever they can get their hands on
Dennisthemenace
12:50 PM
Yes, the 1119 series is bad for that. For the future grind the socket flat. For the present get a medium size chisel and hammer and a bit of heat and cool on the clutch threads
