weedkilla
- 8:27 PM
- Dec 4, 2015
- lobethal, South oz
I've had a husky 550 for a while and it's now my most used saw. I've done the easy stuff, it's muffler modded, squish is 018 with a thinner base gasket and I've cleaned up the ports. The transfers had some pretty ugly casting flash, all smooth and pretty now.
It'll happily pull a 64dl 3/8 setup in Aussie hardwood, it's nipping at the heels of how I remember my 562 when it was stock, or right there with an open ported 268.
Obviously I want moar....but its good enough I'm concerned about going backwards. There is obviously some thought gone into the transfers, a lovely curve cast into the back/top wall of the uppers. The uppers are slanted - I don't know what would change if I made them flat, or even if I could replicate the original shapes if I moved them significantly.
I don't see an obvious way to make it better.
Those that have run a well ported version - Whaddya reckon? Is it worth the time and a couple of Pistons to try and find some more go?
I'm moving house at the moment, so this is going to be rattling around my head for another couple of weeks before I even think about putting the jug on the big spinny thing.
