How many degrees timing advance MS 400?
Duane(Pa)
It's the chain...
6:01 PM
Centre County
Spooky. Your backwards. The saw rotates counter clockwise when viewed from the flywheelside. You want to make the fly wheel go further or "advanced" in its position counter clockwise relative to the crankshaft so the spark happens sooner.
Magnet gets to the coil earlier
6:01 PM
Do u remember a 67 cc saw with actual torque? Ignition are so aggressive on the 680/620/7310, u dont have to mess with em.
Still in production and will over oil a 32" bar. 😃
Most echos have aggressive timing like that which is part of what adds to their torque.
wilfrie
Active OPE Member
12:01 AM
Wageningen, Netherlands
i like 10deg
I thought maybe the magnesium piston of the 400 couldn't handle the extra heat as well as the 362, and since they share the same flywheel, the 400 doesn't seem to be cooled any better than the 362.
But just to be sure, does anyone else notice the saw getting hotter with an ignition advance, or at least not experience any problems with it, not even in the long run, not even with a 10-degree advance? If that's the case, that reassures me, and I'll keep it that way. Thanks for the replies anyway.
It's strange, by the way, that they advertise the 400.1 as having improved cooling. If that wasn't a problem with the old 400, why does the 400.1 need better cooling?
lehman live edge slab
Live Action
5:01 PM
Mn
Just because even if not an issue better cooling won’t hurt. I believe the magnesium alloy piston transfers heat better to the cylinder than aluminum as one of the benifits. It was also lighter to put less load on the crank and bearings of the 362.
6:01 PM
They are also cooled by fuel when it hits the piston. Heat can be a good thing as long as there’s ample fuel and air to get the job done. Heat will make the engine run lean and running lean will make it run hot. Adding fuel will cool it down and make more power in the process as long as it has the ability to put out more fuel
