How i can build race pipe
Racer
3:06 PM
Earth
Hello guys. I need weld race pipe like this:
Can you show me a manual on how to do this correctly?
I'm interested in the exact dimensions, and also advice from experienced guys
Thanks
lehman live edge slab
Live Action
9:06 AM
Mn
There are calculators on line for building pipes that you can put information into like rpm/engine size ect. These will give you a start for length/diameter/ stinger or not how long of stinger. And yes it will be a start you may need to alter length of cone, stinger or overall length to get it to run as desired. You may also get the pipe close but need to tweak the porting to get the most of it. Then when that’s done you may need to put on a new carb because the pipe flows and pulls so much charge you need a bigger one. It’s a rabbit hole and a ton of work to get it right, I’ve never done one but know a few who have tried on snowmobiles with mixed results. You will also need a slip roll to make cones ect for the pipe usually lots more involved than plugging in numbers and just building it.
Live Action
9:06 AM
Mn
You also need to decide gas or alcohol, full ported race saw or just for messing around ect. If it’s full race you need to start with a ported saw and build pipe to it probably to achieve your goals. You a good tig welder? Good at math for the fabrication part and have ability to roll and bend sheet metal? If you don’t have the ability and equipment might be best to have a person that has built pipes do it for you but that’s what you need to decide.
heimannm
9:06 AM
Dike, Iowa
Find a copy of Gordon Jennings "2 Stroke Tuners Handbook". There is a chapter devoted to "Expansion Chambers" that explains in pretty simple terms what happens and how design changes affect the performance.
Here's a snippet from that chapter:
Mark
Hinerman
9:06 AM
NE OK
Mark
Pretty simple................................uh, OK
David Young
Safety First !!!!!!
10:06 AM
vt
Husqvarna 346XP Jonsered 2149 2150 2152 2153 Performance muffler chainsaw  pipe | eBay
Anything can be a race pipe if you are dumb enough or drink the the crayon water koolaid
