How do you advance the timing on old chainsaws?
Ronie
2:26 AM
NC
How would I advance the timing on a poulan 31, would a larger points gap do it?
Maintenance Chief
2:26 AM
South Carolina
Thats the understanding that it advances the spark ,but timing of the cylinder is still set with the flywheel. Really 2 different kinds of timing.
Ronie
2:26 AM
NC
If I take some off the key would it react like a modern day saw?
Maintenance Chief
2:26 AM
South Carolina
Possibly, but it is more likely to bite you(kick back) with the points set up.
Honestly some of the better results I get is from adding a chip and disconnecting the points. The chip has alittle more advance built in and if you do decide to shave the key you don't have to worry about affecting the dwell of the spark.
Ronie
2:26 AM
NC
I have looked at the chips and they don't cost to much. Thanks for helping me out.
msellers
11:26 PM
Nevada
Here is another bit of info I found enlightening on this subject. Still wrapping my head around the proper application of it though.
Mike
Ronie
2:26 AM
NC
Mike
I think I'm going to have to read that a couple more times before I understand it..
msellers
11:26 PM
Nevada
Definitely not something I am ready to attempt on a motor I care about. Would hate to have a saw blow up on me.
Ronie
2:26 AM
NC
I ordered a couple of them chips to see how they do.
wcorey
2:26 AM
ma usa
Appears to me the whole points/coil plate is slotted and it's set toward the retarded side, so there would be room for advancement.
Slotted/rotating points plate or distributor is pretty typical on many if not most points setups.
Changing the flywheel to coil timing doesn't change the ignition timing in this case, only the place where the points open does that. Which is why changing the points gap does change ign timing.
The coil does need to rotate along with the points to keep the energy pulse from the coil in time with the points opening, too far off and you get weak/no spark unless running a cdi or similar.
The points open by a cam lobe on the crank, so moving the flywheel in relation to the crank in this particular instance is a bad idea...
<Edit> Looking at the picture again I'm not so sure those slotted holes will rotate the whole setup, could be just for setting up the coil... One way to find out...
Ronie
2:26 AM
NC
It looks like it will all rotate together, I'll play around with it and see what it likes thanks.
