- 8:28 AM
- Dec 24, 2015
- Coastal Oregon
Hey guys -
I'm putting my recently rebuilt 346XP up for trade. It's an OE that thinks it's an NE. I went through this for a member here for a potential trade deal and then we decided to go a different direction. The member wanted all new components inside, so I split the case and installed new bearings and seals (OEM PTO side, Nachi on the flywheel side), a new OEM gasket set (except for the base gasket, I had to make one since I'd given the OEM gasket to a different member previously). The carcass I'd gotten from another member here on trade. The bearings and seals did not need replaced but the member that was potentially getting the saw wanted it done.
The top end is a new OEM NE kit that I got long ago from Spike60. It is the cylinder without the compression release. The crank is minty and the ignition is the black unlimited coil. The carb is the stock Zama. Other new OEM parts: Top cover, brake handle, 455/460 clutch cover, and sprocket. It's also got the Adirondackstihl dawg with a new chain catcher. I've got it set up with a 16" Windsor bar currently and Oregon 76 chisel chain.
Mainly what I'm looking for:
Mac 125 or 797 parts or a carcass
Large Olympyk carcass or parts
Large Alpina carcass or parts
Foredom and porting stuff
I'm not really looking to sell, just looking to trade.
