a3fins
New OPE Member
- 10:25 PM
- Jan 4, 2025
- Connecticut
Hello,
Not sure how this happened but I need some suggestions on a Honda GX240. It was surging. Instead of rebuilding/cleaning the carb (engine is about 18 years old) I bought an OEM carb from JacksSmallEngine.com. I replaced the carb and the gaskets, replaced the fuel filter, put in an OEM spark plug. I go to start it up and nothing. It’s getting a spark. I tried starter fluid, and nothing. I put a little gas in the cylinder head and nothing. I checked the compression and it doesn’t even hit 50 PSI. I understand it should get 120 PSI. I took the valve cover off and both valves are moving, neither is stuck. What the heck is going on with it. I cannot figure it out.
