Honda GX120 on pump
Dustin4185
1:24 AM
East TN
Gentlemen, we have a Honda WB20X water pump with a GX120 engine. I was filling our nursery tank and everything was going good then it backfired and wouldn’t hit a lick! Pulled plug at the shop and it has fire. Won’t hit on ether either. I didn’t check compression, but will tomorrow. Fresh gas, but wasn’t mine. I loaned it to someone and they filled it up :confused:. This pump/engine is a 2008 and has had a rough life pumping water and chemicals in an ag situation so I’m not mad if it decided to drop a valve or something like that, lol. Where do I start?
GMB74
1:24 AM
Vermont
Take a fuel sample. Water or Diesel in the tank?
Did it over-rev and bend a pushrod/ pop off a rocker?
When taking a compression reading, remember the compression release is going to cause a low reading. A reading of 50 PSI is still ok. The old thumb over the sparkplug port test is just about as accurate as a gauge reading.
Dustin4185
1:24 AM
East TN
I’m thinking a fuel issue. I drained the tank and it doesn’t look the best. I was waiting to get a plug before I try everything again. Pulled the rocker cover and everything seems fine. Flywheel key is in place. Coil and fly wheel are rusty. I guess that’s part of it being a pump. I’m going to clean everything up and give it a shot tomorrow. Is there anything that can be put in the flywheel to keep it from rusting?
