Help with a stihl 041av super
Hunter72
6:39 PM
Northern Il.
I have a very nice low use 041 that will lock up due to bar oil leaking into to crank, then into piston area after sitting for a few weeks. Are there any seals in the oil pump that can cause this? Or am I looking at splitting the saw to replace the case gasket ?
how57
It’s a city! Not a smoke!
4:39 PM
Weed Ca.
Yes. Pull the oiler out and get a new rubber seal.
how57
4:39 PM
Weed Ca.
I will give it a try.
Thank you
I’m sure once you see it you’ll have it fixed in no time. If you need a part let me know. Luv the 041 Super.
Hunter72
6:39 PM
Northern Il.
Will do I should get to it early next week.
Thank you
