Help needed extracting snapped cylinder cover bolt on 036
hoss29860
11:53 PM
North Augusta SC
Ok I found a 036 at the local flea market piston and cylinder looks good it was missing the carb and ignition coil also found out that someone has snapped off the stud on the cylinder that the top cover locks on to . Has anyone had any luck removing broken ones and maybe has a few tricks to share I'm all ears
Agent Smith
Hack of all trades
11:53 PM
Northeast ohio
You have a welder? If so, I'd try this method on that cover stud. I had a 026 with a broken cover stud and this method worked.
If no welder then drill a small hole in the center, apply penetrating oil, tap in a small broken bolt extractor, heat the area and try removing. Worst case, you'll have to drill out the stud, repair the hole with a helicoil and install a new stud.
hoss29860
11:53 PM
North Augusta SC
I have access to a welder at work I might give that a go it definitely appears someone has drilled a hole in it already so I might try chasing it out with a broken bolt extractor thanks for the tip
av8or3
11:53 PM
Waleska,Ga.
Remember, heat is your friend.
