Oh a dedicated saw bench would be nice........maybe some day.
I like a high slanted shelf with meters on it. Small distance below another shelf for leads. I do electrical on the same bench.
And put outlets.....air and electrical under the bench also.
And if the work is small.......a slide for your waist like a watchmakers.
Yeh, I néed to contain all the saw stuff to one area. That way I can utilize the barn for larger projects.
I do like the slide idea, could come in handy at certain times,
@Red97 ...I have a pair of 6' plug strips that I could send you, if you'd like?? THey were left over from a job, and they are just taking up space here View attachment 39819
Thank you for the offer, it is already wired with outlets up at the top of the wall. Probably only need to add 1 outlet for the bench where I plan to plug in my impact charger.
